duty cycle
Discussion in 'Homework Help' started by arvind, Nov 4, 2004.
  1. arvind
    Nov 4, 2004
    18
    hi
    what is meant by duty cycle of a square wave. for what other signals is it defined. also, when we write statements like 1 bit comparator, 1 bit full adder etc. what precisely do we mean. please solve my problem
    thnx :) :) :) :rolleyes: :rolleyes: :rolleyes: :blink: :blink: :D :D :p :p
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The duty cycle of a square wave is the ratio of on to off time. For example, consider a square wave that is 0 volts off, and 5 volts on. A 100% durt cycle means the observed voltage stays at 5 volts. If there is an equal period of on to off, then the duty cycle is 50%, and so on.
    One bit adders and such actually add or compare two bits of information. But there's only one output signal.
  3. arvind
    Nov 4, 2004
    18
    hi beenthere,
    thnx very much for the info,
    my best
    arvindarvindarvind
    :) :) :) :) :) :D :D :D :D :D :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes:
