hello friends,
Suppose my car battery current voltage is 10V and the alternator is charging my battery during the car run so if the voltage arriving at battery terminal is 13V then what value of voltage i should consider in my equivalent circuit of battery?
my equivalent circuit consists of a resistance in series with parallel combination of a capacitor and resistance. For this circuit i have the values of voltage and current generated by the alternator. So to calculate the total impedance of the circuit should i directly divide voltage(alternator) by current(alternator) or it would be something else?
The reason i am confused is because the battery current voltage is 10V and at time t=1s the alternator voltage is 13V and current is 35A. Then to calculate total impedance of the battery should i divide 10/35 or 13/35 or i should consider both the voltages that is 10V and 13V???
please help
thanks
please help
thanks
