OK, you guy's know I ask dumb questions, so here's my latest. If you have two separate voltage sources, A and B that are joined at common/ground, and at positive in a diode "or" situation what is the voltage coming out of the "or" to the rest of the circuit? Example -
Source A, +10VDC, to diode A, to circuit
Source B, +20VDC to diode B, to same circuit
Sources A and B negative pole tied together as common ground
What would the voltage be going into the circuit?
