dumb question
Discussion in 'Homework Help' started by mattm, Aug 10, 2009.
  1. mattm
    Aug 5, 2009
    19
    If you increase the resistance in a RLC series curcuit will it give you broader tuning at the resonant frequency?
  2. KL7AJ
    Nov 4, 2008
    2,047
    295
    Yep. And lower Q
  3. ELECTRONERD
    May 26, 2009
    1,146
    16
    But that should increase impedance, shouldn't it? Which you don't want to have too high of a impedance.
  4. KL7AJ
    Nov 4, 2008
    2,047
    295
    At precise resonance, the ONLY impedance you'll see is the resistance.
    Depending on the application, you don't always have a choice of the resistance. An antenna is a perfect example. An antenna is electrically equivalent to a series resonant circuit. The radiation resistance is pretty well determined by the physical size of the antenna. And actually, for an antenna, it's GOOD to have a high radiation resistance, which generally lowers the Q of the circuit.
    In any case, the Q is determined by X/R, so all other things being equal, a larger L/C ratio wil result in a narrower bandwidth (for a simple series circuit).
    Eric
