Dumb question. i'm a newbie but need help!
Discussion in 'The Projects Forum' started by paldep, Mar 3, 2016.
  1. paldep
    Mar 3, 2016
    41
    I bought a
  2. Kermit2
    Feb 5, 2010
    3,849
    965
    The preamp has a 5.5 volt max VCC and I believe the datasheet said 2.4 volt minimum.
    If your power amp needs higher voltage you will have to add a 5 volt regulator.
    As for connection you simply add two wires to the preamp output and plug both into your stereo power amp.
    paldep likes this.
  3. wayneh
    Sep 9, 2010
    12,382
    3,239
    What battery would you like to use? 3 AAs in series would work, 4 if you use rechargeable Ni-cads. A single Li-ion battery (3.7V nominal) would probably work, but as it discharges your power amp might not be happy (data sheet says 3.6V minimum). A sealed lead-acid (SLA) at 4.5V would work. There are lots of options since your two devices overlap in the 3.6-5V range.
    paldep likes this.
  4. wayneh
    Sep 9, 2010
    12,382
    3,239
    Two li-ion in parallel at 3.7V? Is that a commercial pack or your own arrangement? The cells need to be (and will be) closely matched in a commercial battery pack. Otherwise it's not such a good idea to put them in parallel.
    You may not be able to use the full capacity of the Li-ion batteries, since they have ~40% capacity remaining when they hit the minimum needed by your power amp.
    And your drawing seems correct for the power. Can't comment on the mic but it looks reasonable.
  5. paldep
    Mar 3, 2016
    41
    Can you suggest me a battery For a portable device with this environment?Thanks
  6. wayneh
    Sep 9, 2010
    12,382
    3,239
    "This environment"? What environment do you mean?
  7. paldep
    Mar 3, 2016
    41
    I mean this two circuits. Sorry. Bad English.
  8. Dodgydave
    Jun 22, 2012
    5,150
    769
    What voltage do you need, and how big or small does the battery need to be, how about 18650 batteries?
  9. wayneh
    Sep 9, 2010
    12,382
    3,239
    He needs something in that range. No idea of any other criteria such as size, capacity, cost, weight, rechargeability, whatever.
  10. paldep
    Mar 3, 2016
    41
    I need a battery such as old Nokia bl 5c. I saw a Project that use pam8403 Board with the same battery. I dont know if i can Connect two batteries of the same size. I dont know if it's safe.
    I dont know in How much time it will discharge.
  11. Dodgydave
    Jun 22, 2012
    5,150
    769
    Discharge time depends on how much current is drawn from the battery, a Nokia battey is approx 850maH, so you can use any combination of current that will give you 850maH
    Example 1mA for 850hours
    10mA for 85hours
    OR. 100mA for 8.5hours
    paldep likes this.
  12. paldep
    Mar 3, 2016
    41
    Thanks! Simeone can help me with the circuit? I posted an image. Is it right?
  13. Dodgydave
    Jun 22, 2012
    5,150
    769
    Your circuit is ok,but the amplifier needs more voltage to work correctly, you may find your amplifier doesn't give much volume at 3.7v.
    paldep likes this.
  14. paldep
    Mar 3, 2016
    41
    Good! I'm happy to hear that. I'll add a 5 volt regulator!
  15. Kermit2
    Feb 5, 2010
    3,849
    965
    Run two 3.7 volt batteries in series for 7.2 volts then add the 5 volt regulator. You can get more of the energy out of the batteries this way. Use a low drop out regulator. They will be called LDO voltage regulators
  16. paldep
    Mar 3, 2016
    41
    If i want to charge the batteries in Series? It's possible?
  17. wayneh
    Sep 9, 2010
    12,382
    3,239
    Do you have a separate, dedicated charger for that battery type, or do you want to build something? If you want to build, I would suggest you choose 4 AA Ni-cad batteries or even the SLA I mentioned earlier. They are much easier to charge properly with simple, do-it-yourself circuits. For a beginner such as yourself, a Li-ion charger is a "big" project that requires a special IC designed for charging Li-ion cells.
