Ductile fracture
Discussion in 'Homework Help' started by Hello, Jan 6, 2009.
  1. Hello
    Thread Starter Active Member
    Dec 18, 2008
    82
    Describe the processes that may occur in a ductile fracture.
    Not sure what the question is asking!
    I know that,
    Ductile fracture leads to plastic deformation with high energy obsorbtion before crack formation occurs.
    Any help is appreciated.
  2. KL7AJ
    Nov 4, 2008
    2,043
    292
    I thought that's what you get when you run over Daffy!
  3. studiot
    Nov 9, 2007
    5,005
    515
    The difference between ductile and brittle fracture is that in ductile you get necking (significant reduction of cross section and elongation) of the specimen before breaking in the tensile test. the break is typically cuspate where the specimen is pulled apart by longitudinal shear forces. Breakage is gradual.
    In a brittle fracture there is little or no necking, and the fracture is often diagonal across section due to fracture by diagonal shear forces. The fracture surface appears microcrystaline. Breakage is sudden.
    Brittle fracture is a cause for concern because you get no warning before it occurs.
