dual voice coil subwoofer
Discussion in 'General Electronics Chat' started by justin77, Apr 3, 2010.
  1. justin77
    Apr 3, 2010
    19
    what happens if you connect one channel of the amplifier to the speaker correctly and the other channel with the polarity reveresed?
    Since its a dual voice coil subwoofer you wil get a very low sound output level.
    Will it damage the speaker?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The output will be reduced. If the drum is centered in the stereo image, the subwoofer will not have an output, as the drives to the voice coil will cancel.
  3. justin77
    Apr 3, 2010
    19
    Now when clipping happens they say that it will damage the speaker since the speaker coil will be stationary and current would flow and the coil will get heated.
    Doesn't the same type of thing happen in this case?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Clipping allows DC to flow in the coils, leading to increased heating. The coil is not actually stationary in the sense of remaining in the undeflected position, but may be deflected in one direction as far as the structure will allow it to move.
    Heating in the case of reversed polarity in the voice coils will be a function of the currents in each, not the degree of deflection.
