Dual transformer placement - Power Supply
Discussion in 'The Projects Forum' started by gtrkid, Nov 4, 2015.
  1. gtrkid
    May 16, 2009
    I'm building a Part 15 AM tube transmitter that has two transformers in the power supply circuit.
    My questions are with regard to the placement of these transformers and the proximity with one another. Are there some general guidelines or best practices I should be following? My current design layout on the board has them about 2 inches apart but can they be closer or is that not a good idea?
    The main one has its primary connected to the AC line.
    Thanks for any advice.
    -Dave
  2. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,685
    1,297
    What is the other one? Current layout image?
    ak
  3. Alec_t
    Sep 17, 2013
    5,967
    1,134
    I vaguely recall some valved/tubed audio amps in the 60s/70s had the output transformer laminations at right-angles to those of the power supply transformer; presumably in an attempt to minimise mains hum.
  4. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Also the use of Toroidal transformers eliminates/reduces the radiated field.
    Max.
