Would like to know if anyone could help me build a circuit for the following project. I know it's simple but I don't have the skill and time to do it. Would also be willing to pay someone to build this for me, but please contact me offline for this. If interested PM me and I will supply you with my Email address.
Here's the project, I have a heat press that currently uses a timer similar to this: Omron H5CN. However there is a need to constantly use two different timer settings. For example, I need to set the timer for 20 seconds, then switch the timer to 60 seconds. I don't want to have to constantly change the timer back and forth. Also, I know there are dual setting timers but these generally work at a timed interval and I need to control when I do it (which varies in time) so this is not an option.
So what I thought was, use two Omron H5CN (or similar) and just have a toggle switch that selects the appropriate timer I want to use. This is a 240VAC project so a little hesitant in just wiring something up simple.
Any help would be greatly appreciated. Or, if you're interested in helping me build this, please contact me via PM and I will send my email address.
Henry
Henry
