Hi! I need to create a dual timer that fullfills the following requirement using 555 or 556 IC: one you press the push button, a led has to blink for 5 seconds, then it must be turned off and a second LED has to be on (no blinlking) for another 75 seconds.
I've seen other dual timer projects that can be considered as a start, but I don't know if I can solve this with only one 556 (2 555) or I need 3 555s (for the blinking part).
Thanks in Advance!
Thanks in Advance!
