Dual temp LCD display
Discussion in 'General Electronics Chat' started by 1-3-2-4, Dec 26, 2008.
  1. 1-3-2-4
    Thread Starter Active Member
    Dec 26, 2008
    194
    I'm building a dual temperature display from a kit but I have a question with the PCB I want to make it neat since it will all be going in a project box.. I'm a little stuck on how to connect the pins from the PIC controller to the female 16 pin header.. do I just solder from the PIC to the female header?
    picture of the schematic is here
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You say you're working on a kit. Doesn't the PIC go on the PCB and aren't there traces from the PIC to the LCD socket? That is pretty standard.
  3. 1-3-2-4
    Dec 26, 2008
    194
    nope you supply your own PCB I ran out of solder tonight anyways so I can pause for tonight.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Make a PCB, or use a generic PCB.
    You don't want to try to solder the header right to the PIC.
  5. 1-3-2-4
    Dec 26, 2008
    194
    I have a generic PCB left over but what had me confused (and I checked multiple times to make sure I'm right) how the PCB should be and the header mounted to the PCB just that the PIC i had to turn the other way to get Pin 1 to point the same way as pin 1 for the LCD. I was doing a solder bridge I already did Pin 1 of the PIC and pin 2 which connect to the header to the right spots. However I need to do the ground for Pin 1 and pin 16 which also connects to (-) on the PIC I can't do a bridge with that.. Would a wire be ok here? I just want the connection to be solid because this will be put in a car. Also i'm a little confused with the voltage regulator it's a part number LM7805C What do I use as power input leads for this?
  6. kubeek
    Sep 20, 2005
    4,691
    806
    If you want to put this in a car, make a real PCB. This will be too unreliable after some time.
  7. 1-3-2-4
    Dec 26, 2008
    194
    after taking a few breaks and running out to find some extra parts I finished.. however when I turn the power on all I get is a row of blocks seen here.
    Any tips why this is happening?
    *edit hmm might be that I forgot to connect D7 up to the LCD when I went to clean up.
    nope still not working just showing blocks
