Dual supply voltage from a 9V battery
Discussion in 'The Projects Forum' started by Teszla, Jan 26, 2014.
  1. Teszla
    Jun 7, 2013
    43
    I want to drive an op amp with dual supply using only a (9V) battery.
    I'm thinking it can be made by having 9V at the +supply, 0V at the -supply and then connecting the ground reference to 4.5V? But would that really work? Would that really be the same as having an actual dual supply?
  2. ericgibbs
    Jan 29, 2010
    2,595
    393
    Its possible use a 'spare' OPA to create a virtual ground for +/-4/5V from a 9V supply.
    Are you amplifying DC or AC signals.?
  3. Teszla
    Jun 7, 2013
    43
    How? :)
    The op amp will be used as a Wien bridge oscillator, so that means the input signal is DC and the output signal is AC.
  4. ericgibbs
    Jan 29, 2010
    2,595
    393
