Would this actually work in real life? It doesn't seem to in LTSpice. (or maybe it can somehow???)
Basically I have 2 power sources that can range from -75V to 75V.
I must keep each supply (specifically the returns) isolated from the other (hence the FWB)
I need to scale the voltage of each supply to 2.5V -/+2.5V to be read by a micro. (where 0V on A or Bout represents -75V supply voltage and 5V on A or Bout represents 75V supply, and 2.5V on A or Bout represents 0V supply)
The orD net will be used on another sub circuit (not shown)
If not can you give suggestions on would you accomplish the goals stated above.
