I've attached a schematic of a couple op amp circuits. There is a sign wave input to each of the amps.
I believe the first should center the sine wave on ground. If the supply voltages were +15.5V & -15V would the output be offset from ground.
The 2nd amp should amplify the sine wave. If the supply voltages were +125.75V & -126.52V would the output positive swing be amplified differently than the negative swing?
