Dual rail power
Discussion in 'General Electronics Chat' started by JasonL, Jul 28, 2013.
  1. JasonL
    Thread Starter Active Member
    Jul 1, 2011
    47
    I got this schematic from the web and I want to know how it works. I included calculations I've done in the attachments.
    I want to know what mode of operation the transistors are in. I'm assuming they're in forward active, but I don't think there is any current going through the collector for either of the transistors because I don't think there is no current going through the base. So, I'm a bit confused.
    I also want to know how this schematic is better than using a voltage divider to get a dual rail power supply.
  2. tubeguy
    Nov 3, 2012
    1,157
    197
    You've got the right idea, but in the real world, diode Vf and transistor Vbe aren't necessarily exactly a 0.7 volt drop. Diode drop may be higher than that and the transistor drop may be lower. The 1 k resistors will compensate for the difference. So, the transistors may be biased on just a bit.
    The transistor circuit may be a bit better than the resistor only divider.
    A better rail splitter is one which uses an op-amp, because the op-amp circuit uses feed back to compensate for changes in current draw.
    JasonL likes this.
  3. tubeguy
    Nov 3, 2012
    1,157
    197
    JasonL likes this.
  4. LDC3
    Apr 27, 2013
    920
    160
    The voltage divider allows only a little current to flow through the middle potential. Most of it is through -Vcc still. The first circuit will allow more current through the middle.
    JasonL likes this.
  5. Sensacell
    Jun 19, 2012
    1,183
    276
    The transistor circuit shown would not be very 'stiff' - it's output impedance is about 500 ohms, any appreciable load will cause the output voltage to deviate.
    You are on the right track, you basically want to create a voltage follower with a low output impedance that can source and sink current. The circuit also needs to be stable when driving a large capacitive loads, as you will inevitably have bypass capacitance in the powered circuit.
