I searched around but was not able to find what i was looking for. Maybe that is because what i want to do is not the right method?
I am open to suggestions as well. I am just stuck.
This is what i have so far but i cannot control the negative side correctly. The top (positive) works but the negative side seems to need negative voltage.
I am trying to have a lower chip count so i don't want to use an op amp if possible.
Thank you for any insight you could lend me.
The bottom is not completed and i left off the buck to the right of the circuit because i cannot even get the correct voltage to it.
I was attempting something similar to the top on the bottom without luck.
Thanks =)
Thanks =)
