OK. In that case, it will be a 1.25v-18v supply.Ohh sorry.. its 0-18 to use as a lab VRPS.. And always there wont be a load as it is a lab power supply.
The LM317 would go into thermal shutdown, which is hard on it.And I definitely have to use a heatsink. I know I cant otherwise.
Note that for a given current, the power dissipation in the LM317 will increase as the voltage drop across the LM317 increases.
For example: you have 20VDC on the input, 18V on the output, with a load of 1 Ampere. Power dissipation is (Vin-Vout)*current, or (20-18)*1 = 2*1 = 2Watts (simplified formula).
You then choose to lower the output to 2v, with the same current (1A)
Power dissipation is now (Vin-Vout)*current, or (20-2)*1 = 18*1 = 18 Watts.
Download National Semiconductor's datasheet for the LM117/LM317. There are recommendations and formulas to determine heatsink requirements beginning on page 9.
The TO-220's tab is connected to VOUT as well as pin 2. If you bolted the tab to the metal case, you would short out the regulator. The only good thing that would result from this is that you would reach 0V for an output - but that's all you would get!Ahh... By the way, can i bolt the LM317 to the metal case? will it short the chip?? Assume as if my case is ground.
In a previous reply, you mention using a couple of diodes to obtain voltage lower than 1.25v. Keep in mind that the Vf (forward voltage) across diodes is not fixed; it depends upon the current flow. See the attached plot of a 1N4002 diode's Vf vs current.
Note that the plot is only up to the first 10% of that particular diode's current rating; as the current increases towards maximum, the Vf will dramatically increase.
