dual polarity from a single supply
Discussion in 'General Electronics Chat' started by Earthshaker, Apr 28, 2005.
  1. Earthshaker
    Apr 24, 2005
    9
    I got thinking the other day after reading an article that used a capicitor to power a small audio project, would it work to use 2 large value capacitors in series with the + terminal on one cap going to supply + (12 v) the - terminal of this cap connected to the + terminal of the other cap and the - terminal on cap #2 going to ground?, therefore providing a center tapped 12 volt supply (actually +6 and -6 v with a common ground), it works with 9 volt batteries to provide +9v and -9v with a common "ground". I don't have any large caps to try this myself.
  2. David Bridgen
    Feb 10, 2005
    278
    Sorry to disappoint you, but it won't work.
  3. Earthshaker
    Apr 24, 2005
    9
    Thanks David I was just curious.
  4. mozikluv
    Jan 22, 2004
    1,437
    hi earthshaker,
    are you referring to this kind of circuit that deriving a dual rail supply from a single rail?
  5. zhi_yi
    May 15, 2005
    9
    hi, what is the function of zener diode there??? on that circuits
    thanks for the answer ^^
  6. David Bridgen
    Feb 10, 2005
    278
    They provide basic voltage regulation. Plus and minus 5.1 volts in this case.
  7. zhi_yi
    May 15, 2005
    9
    oh, i c, thank you ^_^
    erm.. please tell me how to use relay with 5 pin on it, 6 v can you give me the example with using relay on a circuit please? thanks :)
  8. David Bridgen
    Feb 10, 2005
    278
    Two of the pins will be the coil connections. Two of them will be to the normally open or normally closed contacts and the other one may be the third contact if they are a change-over set.
    The coil could have its energising voltage applied with a mechanical switch or a transistor.
    It would be helpful to you if you knew the contact rating.
