It's a great thing to have if you like to tinker, which you apparently do. Sure, you can buy LC meters, but the affordable versions are made in China, Korea or Vietnam, and you would have no idea how to fix them if they broke. The project is something that you can build yourself, calibrate yourself, and fix it if it breaks. Besides, it'll give you a cursory intro into using microcontrollers for a very practical purpose. Nothing like creating a very useful tool while you're learning.Thanks for the links on the project meter. That is definitely a good thing to have and I will be putting one together in the very near future.
The Mr.Fusion idea is very nice too. Wish we had a local outlet around hereJust wait a decade - they'll be selling them in the Big Box-Mart for $39.99 each. Of course, that helps very little now, but it's something to look forward to.
Back in '73, a guy I worked with had a '71 Pinto Runabout that he'd tricked out. Changed the camshaft timing, advance curves, compression ratio, etc, put on traction bars, wide rear wheels, etc.And man-oh-man what I wouldn't give for a nice old Pinto Runabout to play with. Those were the days of EASY modifications.
He could jump the front wheels over a tall beer can.
The problem is trying to keep up with the technology. Don't feel alone there. Mom has no clue how to set the clock on the VCR. I don't know how to reprogram an ECU; but at least I know that you can reprogram it via an OBT-II/OBT-III port. After that, I only have an inkling on what goes on.There are so many variables on the new engines today that, although a good challenge, isn't near as much fun as experimenting with the older versions.
Look, you have to have some kind of controls. Really, the only way to do that nowadays is via computers; whether uC's or larger. Unplugging everything isn't the way to go, unless you have a better replacement.Of course, one could always pull the spout connector and revert back to base engine running without the processor controling fuel trims as some people on some forums have done, but you are still unable to adjust spark timing, and despite what they may claim, I tried it and the results were just as I had predicted.
Creating a better replacement would require a great deal of time on a dynomometer to create a viable default map, and then extrapolate from there. It's not a simple thing, would take a heck of a lot of time, and cost a heck of a lot of money. Unless you have extremely deep pockets, this route isn't for you.
There ya go!would it be more correct to say 'a better job of controlling the inefficiency'!
Don't expect much from either circuit.I have almost completed the boards for the 2 different circuits that you and Ron H provided. I am hoping the cold will hold off long enough for me to try them both out before having to quit for the winter.
Ron_H's circuit will do what you originally asked for, but you won't see any benefit out of it. You'll see one of two things; no change, or ECU going open-loop. The reason is because the 450mV threshold will or will not be crossed; nothing else is changed.
My circuit is far more risky than Ron_H's circuit. Mine will change it's output due to variations in EGT temperature. However, neither circuit is viable, due to the limitations of the narrowband lambda sensors.
We're really beating a dead horse here. You can't realistically expect to modify the output of a narrowband sensor, which is why I was so reluctant to post the circuit to begin with.
Basically, both circuits are a huge waste of time and money.
Unless you follow my very early suggestion of broadband sensors, you will be just spinning your wheels and throwing your money away.
But, it's your money. If you want to try to convert a narrowband sensor to a wideband sensor, it's up to you. I can only suggest that your results will be extremely dissappointing, but that's your choice.
You NEED wideband sensors. Otherwise, you're just throwing your money away. Without wideband sensors, you have NO control over your A/F ratio, unless it's right at stochimetric. The addition of H2O2 will throw everything out of whack, and you will have no way to compensate for it.
There's a rather steep learning curve when you're getting into it. It's not so bad once you've gained familiarity. However, it takes a lot of time and research.As for building the circuitry and toroid coil....that seems WAY out of my league, at least at present.
I didn't know that you were in the Corps. We might've stomped some similar turf along the way.When I was a tech back in the Corps, I repaired loads of gear. But the designing aspect of the electronics was never really a requirement for the job. So although I toyed around with some simple designs of my own.....nothing like trying to match the resonant frequency of a circuit in order to split an atom ever came up. (Imagine that!) Oh well, I guess this old dog will just have to try and learn a new trick or two. That will be some learning I will attempt over the long months ahead.
In the 70's, I witnessed a radar tech make a backwards somersault into a trashcan while they were attempting to measure the HV from a transmitter. The probe had a crack in it. 18.5kV can give one a nasty jolt, particularly if the person is standing on an aluminum structure.I agree w/you that 50kV across the plates in that gang capacitor doesn't interest me much in trying. I have been toying around with ignition coils of various types as well as a 14kV neon sign transformer, but not being able to calculate exactly what I need to do has kept me from doing all but simple experiments on the bench...i.e. plasma arcs, etc. I am in NO WAY afraid of electricity, but I have a VERY heathy respect for it. Once took a jolt from the brass winding rod in an 18kV power supply I was troubleshooting that taught me the respect in a hurry! Threw me up against the wall out of my chair like I was a rag doll! MOST IMPRESSIVE!
That would take a good bit of experimentation. They're optimized for ignition, not alternative purposes.Last time I ever made that mistake. (Thankfully I had one hand in my pocket at the time. LOL) By the way, how would I figure the optimum working frequency of a given coil? (Automotive coil I mean)
LC time. You need a way to determine the inductance. You don't have that right now.Based on engine rpm/hertz, I know the coil will fire over a fairly wide range of frequencies, but is there a way to know it's optimum frequency?
Usually, schematics on "HHO" websites are made by amateurs that are poorly designed using commonly available yet hopelessly outdated components that have terrible bandwidths.I want to do more plasma arc experimenting this winter, and I am looking for a small PWM to build that would be tunable to the optimum frequency range of the ignition coil.(These are the newer style Coil-On-Plug type individual coils I am experimenting with) I haven't had much luck with my HHO PWM as the frequencies are way too high I believe.
The LM324 PWM circuit is a prime example. On the website, it's touted as the latest, greatest thing. However, the LM324 is ancient technology, and is really unsuitable for anything over a couple of kHz.
Link: http://alt-nrg.org/pwm-v2.html
Really, it's a bad circuit. It uses an opamp as a comparator at one point (U1C) which will likely cause it to fail soon; opamps are not designed to be run open-loop, where comparators are. 324 opamps have terrible rise/fall times. Even 555 timers have far better times than that opamp does.
Why don't you publish the schematics of the circuit that you're using? We can't help you otherwise.
