dual-gate s.c.r.....how do i use them?
Discussion in 'Electronics Resources' started by jimw83296, Apr 25, 2016.
  1. jimw83296
    Apr 25, 2016
    a friend gave me an old (expired) ionization-type smoke detector.....inside, i found what i at first thought was a transistor, it wasn't.
    it was a dual-gate thyristor........how do i use a thing like that?
    ordinary (single-gate) devices, i know how to use........these things??.......duhhh!
    oh, in case your'e wondering......it's inside the detection chamber itself......
    does anyone have the schematic that relates to this application (that would be most helpful to me)
  2. RichardO
    May 4, 2013
    1,342
    431
    I am not familiar with a dual-gate thyristor. Do you have a part number for me to look up?
  3. jimw83296
    Apr 25, 2016
    sorry, no......i wish i did.
    but if you do decide to go after one yourself, you should be aware that those smoke detectors use a radioactive substance (Am 241).
    this is 1 of the top 5 nastiest radioisotopic substances known to man.
    fortunetly, it is contained in a capsule that you need not tamper with in order to get your hands on the thyristor (although, they are both located inside the ion chamber).......just be careful, and dispose of that Am 241 capsule properly at your local hazmat facility (and, for god's sake DON'T open that capsule!!!)
    anyhow........the reason i ask about these devices is because they can be used to make a surprisingly sensetive ionization chamber-type radiation sensor.......hang on....the bulb just turned on.....back in a bit.
  4. jimw83296
    Apr 25, 2016
    sorry, bulb's a bust.
    anyhow.....i could be wrong about the thyristor......it could be a j-fet (totally different device, i know).......
    or maby i've come across 2 entirely different systems for interfacing the ion chambers.
    who knows.....stranger things have happened.
  5. RichardO
    May 4, 2013
    1,342
    431
    Maybe not a J-FET but a dual gate MOS-FET?
  6. dl324
    Distinguished Member
    Mar 30, 2015
    3,384
    653
  7. jimw83296
    Apr 25, 2016
    DENNIS......a most sincere thank-you!!!
    i knew there was something special about those devices.......and now i know.
    faster, potentially much more sensitive, faster response times.........ultra sweet!
    as soon as i can, i'll post a coupla circuits using this device.
    in the mean time......need a custom circuit board, but can't afford, or cannot get the materials needed to make one?
    no problem!!!.......a peice of typing paper, a "bb" graphite pencil, a pen, some scrap copper, some drain cleaner, and last (but not least)
    an old wall-wart (pref. 12V, 500mA, or better) with 2 gator clips.
    procedure:......draw tour desired circuit traces on the paper using the pencil, mark holes and bridge points using the pen. (bridge points are small "jumper-type" disposable traces used to connect all the other traces together during the electrolosis phase
    remember......draw in reverse of what you want....here's why:....the graphite side is your circuit side, that way, the copper is partially embedded into the paper.
    when electrolosis is complete. just use a pin to make any holes you need, and don't forget to cut those bridge points!
    then, just install your parts like on any other circuit board.
    have fun (but stay safe).....HAPPY TINKERING, ALL!!!
    l8er!....;)
