Dual Full-Wave Rectifier Power Supply Issue
Discussion in 'The Projects Forum' started by cece671, Mar 29, 2015.
  1. cece671
    Mar 28, 2015
    6
    Hello everyone,
    I am currently prototyping a power supply to power filaments in a vacuum tube circuit. I am using a dual full-wave rectifier design to generate +6.3V, -6.3V and 12.6V.
    I breadboarded my design and was testing the circuit for AC ripple when capacitor C2 blew from overheating. I then realized that I had failed to connect the second resistor across the 0V / -6.3V terminals to which I had just attached my scope probe.
    Could this be the reason why the capacitor overheated? Is there a design flaw that I fail to see?
    I have attached a jpg of the circuit design with the second resistor omitted voluntarily to illustrate accurately what I was testing.
    Material details:
    Transformer: 120VAC primary, 12.6VAC 2A secondary
    All Diodes: 1N5401
    All Capacitors: 6800uF 10V Electrolytic
    Load: 10K 1/2watt carbon film resistor.
  2. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    Why do you want to have a DC voltage for the filaments?
    The peak voltage will be almost 9 volts.
    In MANY circuits the filaments are directly powered with the 6.3 or 12.6 volts AC from the transformer.
    Bertus
  3. Dodgydave
    Jun 22, 2012
    5,141
    767
    why dont you use the AC to feed the filaments, also the caps should be 16V rating.
  4. #12
    Nov 30, 2010
    16,665
    7,310
    6.3 VAC x 1.414 = 8.9vDC at no load, theoretically.
    You either had a bad capacitor or you had it installed backwards.
    Still, you're running the capacitors with almost no safety factor on the voltage rating.
    The math works...until a little disturbance arrives on the power line.
    The maximum extended life of a capacitor is when the voltage rating is about twice the voltage applied.
    Personally, I don't care if you want DC for filament heaters.
  5. cece671
    Mar 28, 2015
    6
    Hi Bertus,
    The power supply will be used to breadboard vacuum tube synth designs. The AC tends to make the circuits noisier, so its a question of quieting the circuit.
    You are right about peak voltage, I am aware of this. As I mentioned this is a prototype and I am still working on the design.
    The 1N5401 diode has a forward voltage drop of 1.2V, so I am still working out how to get it down to about 4.45Vdc to achieve peak voltage of 6.3Vdc.
    Thanks for responding so quickly.
  6. cece671
    Mar 28, 2015
    6
    Hi Dodgydave,
    As mentioned to Bertus, DC is mainly to keep the circuit quiet.
    Agreed, my first design had 10,000uF 16V Electrolytic capacitors and I second guessed myself when I calculated for 6.3Vdc peak voltage.
    Thanks for your quick reply.
  7. MrChips
    Oct 2, 2009
    12,624
    3,451
    You want 6.3VDC to give the same heating power as 6.3VAC RMS.
  8. cece671
    Mar 28, 2015
    6
    Hi #12,
    You are right, I was working a little too close to the 10V limit. This is definitely an error of judgement on my part.
    My original design had 10,000uF 16V caps. Which will promptly replace the 10V I was working with yesterday!
    I will be working to achieve 4.45Vdc (rms) x 1.414 to get to my 6.3Vdc (peak).
    Thanks for your quick response.
  9. #12
    Nov 30, 2010
    16,665
    7,310
    The 1N5401 has a forward drop of 1.2 volts at 80 amps!
    A rectifier has a performance curve. Please examine the spec sheet attached.
  10. cece671
    Mar 28, 2015
    6
    Thanks for the datasheet. I admit, I was far off.
  11. tcmtech
    Nov 4, 2013
    2,107
    1,747
    If it was me I would have started with a 10 volt center tapped secondary transformer. After the typical voltage drops for the diodes are factored in you fall well within the working voltage range that most any tube heater element will work on.
  12. MikeML
    Oct 2, 2009
    5,451
    1,066
    With indirectly heated cathodes in a tube, why bother with DC? They put indirectly heated cathodes in tubes in the 1940s just so you dont have to go through all of this monkey motion...
  13. crutschow
    Mar 14, 2008
    13,475
    3,362
    Any AC voltage/current around low-level high-impedance preamp tube circuits can cause pickup of AC hum, even for indirectly heated cathodes. Since such hum is very annoying in audio circuits, high grade tube audio preamps often use DC on the filaments to eliminate that as a source.
  14. crutschow
    Mar 14, 2008
    13,475
    3,362
    True. To get near 6.3VDC from 6.3VAC in a capacitor filter design you will need 3 diodes in series (2 besides the rectifier diodes).
    For a given load you can further tweak it by adding a small resistor value in series with the load.
  15. MCU88
    Member
    Mar 12, 2015
    360
    35
    Yes RMS Root Means Square. I had one funny teacher that told us that... first you root it then you square it hahaha... He literally did the rooting part with his hips moving in and out.
    But we get the RMS derived from 0.707 x Peak. 1.414 x RMS to arrive back at the peak. 2.828 x RMS to get the Peak-to-Peak.
  16. MikeML
    Oct 2, 2009
    5,451
    1,066
    Oh, well, maybe we should be using things like transistors or integrated circuits that don't require heaters?;)
  17. Dodgydave
    Jun 22, 2012
    5,141
    767
    i thought Mosfets were "heater-less valves" :D
  18. MCU88
    Member
    Mar 12, 2015
    360
    35
    Lower case "i" for you and upper case "m" for mosfets.
    Mosfets are more important than you?
    Treeman likes this.
  19. crutschow
    Mar 14, 2008
    13,475
    3,362
    Obviously you don't belong to the world of the irrational audiophile where "tubes sound better than transistors". :rolleyes:
  20. tcmtech
    Nov 4, 2013
    2,107
    1,747
    Personally I value the function of mosfets far more than I value the functions of many people. :D
    Grammar Nazis being one of them. :p
    MCU88 and Dodgydave like this.
