Hi All,
I have sourced a buck boost converter which seems to satisfy my requirements, they are independent outputs so i can use them both as required.
now, I also need to use a battery (backup). I am wondering if it would be possible to get a BMS (ie bq24702) and integrate it with the above?
ie, if the power into the dc/dc IC is live it also feeds the BMS and charges the battery.
If the power is lost the battery will supply power to the DC/DC (and loads).
Is this feasible with mosfet switches?
(might be too much....)
