Dual DC Converters for split rails
Discussion in 'General Electronics Chat' started by fsonnichsen, Oct 29, 2013.
  1. fsonnichsen
    Jun 6, 2013
    15
    I need to build a split rail converter with 24V in and +15V, -15V out. There are not a lot of converter modules with this configuration however in the past I have succeeded by putting two 24->15 converters back to back sharing a common ground. (I don't want to start from scratch and build a converter but prefer to assemble with commercial modules)
    I would like to insure best practices here, and wonder if there is a "gotcha" document discussing any problems or procedures with this type of design.
    Any comments appreciated
    thanks
    Fritz
  2. antonv
    Member
    Nov 27, 2012
    149
    27
    I have successfully done the same, as long as their outputs are isolated so that they are floating.
  3. #12
    Nov 30, 2010
    16,656
    7,295
    I have even floated a 5 volt switching supply on the 400 VDC output of a vacuum tube rectifier (5Y3). The isolation in those SMPS supplies can be very good. Read the documentation before trying several hundred volts!
  4. fsonnichsen
    Jun 6, 2013
    15
    OK guys--thanks for the advice!
    fritz
