Dual BC547 NPN Transistor IC?
Discussion in 'General Electronics Chat' started by cce1911, Oct 6, 2013.
  1. cce1911
    Jun 11, 2013
    41
    I have a circuit that requires 2 BC547's in a T0-92 package. Is there a dual version of this IC in a PDIP package?
  2. paulktreg
    Distinguished Member
    Jun 2, 2008
    623
    124
    Don't think so?
  3. t06afre
    May 11, 2009
    5,939
    1,222
    Not that I know about. But why do you need such a part?
  4. cce1911
    Jun 11, 2013
    41
    I'm just trying to reduce the number of components that I need buy and assemble. My circuit simply takes a momentary input and outputs a pulse based on the RC time constant.
  5. MaxHeadRoom
    Jul 18, 2013
    10,841
    2,519
    You may just get away with a single 2n7000, Two components.
    Max.
  6. cce1911
    Jun 11, 2013
    41
    Max,
    Are you suggesting to get rid of the 2nd NPN and the 10K resistor and only go with a single MOSFET?
    -Capel
  7. MaxHeadRoom
    Jul 18, 2013
    10,841
    2,519
    Yes.
    The original 2n7000 was designed as a FET darlington equivalent, named a 'Fetlington'!
    And was intended to interface TTL and CMOS to higher loads and voltages.
    But I always keep lots on hand and found them a real work horse in the right application.
    You keep the 10k load and the first 100k on the input.
    It just might work for your circuit.
    Max.
  8. cce1911
    Jun 11, 2013
    41
    What about leakage? I would like the 3v button cell to last as long as possible. The switch is only triggered intermittently and I don't want to have to change the battery every day or two.
  9. ian field
    Oct 27, 2012
    4,447
    791
    There used to be pages in the data books of dual transistors & JFETs for external long-tailed pair on the front end of op amps.
    Usually in a 6 pin TO18 or TO5, they were designed to be closely thermally and parameter matched.
    They're not so popular as they once were, but you may find something that's a very near equivalent to the 547.
    The BC547 was pretty much the cheap plastic version of the BC107, so that might help when comparing parameters.
  10. cce1911
    Jun 11, 2013
    41
    Max, I can't take the second NPN out. That's my TTL logic inverter.
  11. ronv
    Nov 12, 2008
    3,398
    1,456
