Dual battery redundancy?
Discussion in 'The Projects Forum' started by susannah, Sep 13, 2013.
  1. susannah
    Thread Starter Active Member
    Feb 14, 2010
    87
    I would like to add dual battery redundancy circuit to my project which uses 3.7v lipo.
    Where i could find circuit plans like this? Thanks
  2. Shagas
    May 13, 2013
    802
    74
    Hmm google doesn't turn up anything .
    What exactly do you need it for? Do you want a backup battery in case the first fails ?
  3. mcgyvr
    Oct 15, 2009
    4,784
    973
    susannah likes this.
  4. susannah
    Feb 14, 2010
    87
    Yes, this is what i want.
  5. susannah
    Feb 14, 2010
    87
  6. crutschow
    Mar 14, 2008
    13,469
    3,356
    The calculated average current draw from you battery is about 1000mAH / 24 ≈ 40mA. A 1N5817 1A Schottky diode has a forward drop of about 0.3V at 40mA giving a power loss of 0.3V * 50ma =12mW. This is about 8% of the 3.7V * 40mA = 148mW the battery is supplying.
  7. susannah
    Feb 14, 2010
    87
    Thanks.
    8% is too much power loss. :(
    Any other way to do this with less power loss?
  8. susannah
    Feb 14, 2010
    87
  9. #12
    Nov 30, 2010
    16,660
    7,305
    Not likely. Mosfets don't work very well at 3.7 volts, you would need one for each battery, and you would need a control circuit...all of this using less than the unacceptable 12 milliwatts.
  10. crutschow
    Mar 14, 2008
    13,469
    3,356
    The problem is preventing the higher voltage battery from charging the other battery going dead. Without a diode you will need a complex circuit to detect the direction of current flow through the battery, such as a Hall Effect device, and then control a MOSFET switch to shut off the flow to the lower voltage battery. It would be difficult to do all that for less than 12mW of power.
  11. crutschow
    Mar 14, 2008
    13,469
    3,356
    Here's a reasonably simple circuit that should do what you want. It uses two P-MOSFETs to switch the battery with the highest voltage to the load. The first comparator compares the two battery voltages and turns on the MOSFET (connects the gate to ground) that has the highest battery voltage. The second comparator is used to invert the signal so the opposite MOSFET is turned off. The comparator's supply voltage is from the two diodes, D1 and D2 so that the highest battery voltage is always powering the comparators.
    The 3MΩ feedback resistor on U1 provides about 50mV of hysteresis so the circuit doesn't oscillate between the two batteries if their voltages are close. You can increase the hysteresis, if necessary, by reducing the resistor value.
    Note that the MOSFETs are connected with the drain side to the battery. This is to prevent the load voltage from charging the battery of the disconnected side through the MOSFET parasitic diode. MOSFETs conduct equally well in either direction so it's not a problem that the normal load current direction is from drain to source, opposite the usual for a P-MOSFET.
    The P-MOSFETs can be any 2.5V logic level (not threshold voltage) P-MOSFETs with 100mΩ or less ON resistance at 2.5V Vgs.
    LM339 quad comparators are shown but you can use the LM393 dual comparator to save the power supply current from the unused comparators. They work down to 2V supply voltage.
    The simulated circuit current was ≈350μA, which is only about 0.9% of the load current.
    View attachment Parallel Battery Switch.asc
    susannah and #12 like this.
  12. #12
    Nov 30, 2010
    16,660
    7,305
    That's amazing!
    Including the idea to run P-mosfets with the most positive voltage on the drain.
    I salute you.
  13. wayneh
    Sep 9, 2010
    12,368
    3,224
    Wouldn't this tend to oscillate due to the load pulling down the voltage of the battery being used? I suppose the comparator hysteresis could be increased as noted to compensate, but if the load is big enough, I'm not sure you could stop the oscillation.
  14. susannah
    Feb 14, 2010
    87
    Thanks, this looks cool.
  15. crutschow
    Mar 14, 2008
    13,469
    3,356
    Oscillations are possible, so you would just need to increase the hysteresis. In this case the load is only 40mA so a high value of hysteresis should not be needed.
  16. wayneh
    Sep 9, 2010
    12,368
    3,224
    I missed that, and I was thinking of a larger load. It should work nicely when the load is small compared to the capacity of the batteries involved. It might be a good solution for some of the requests around here for ORing power supplies together.
  17. #12
    Nov 30, 2010
    16,660
    7,305
    That's why I got a screenshot and a datasheet:p
