dual bank solar battery charger
Discussion in 'General Electronics Chat' started by silverirv, Jul 22, 2008.
  1. silverirv
    Jul 21, 2008
    Hi :),
    Does anyone have a very simple circuit for charging (2) 12 volt marine batteries (approx 100 amp hr.each) from a single 15 watt solar panel and maintaining isolation between batteries ? Thanks for any help you can provide.
    silverirv :)
  2. blocco a spirale
    Jun 18, 2008
    1,459
    369
    Due to the high capacity of the batteries and the relatively modest solar panel output, I would just connect the panel to the batteries via a 3A diode per battery and see how it goes.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Blocco's suggestion isn't bad.
    Shottky diodes will have far less Vf (forward voltage, or voltage loss) than standard rectifiers will.
    Overcharging batteries will damage them. You will need a method of determining when the batteries are charged, and to cut off the charge current - or clamp the maximum voltage.
  4. rherber1
    Member
    Jan 6, 2008
    15
    It all depends how much voltage you are prepared to drop.
    Depending upon the expected current draw the use of rectifiers (even Schottky) can produce a significant volt drop. These days the trend is to use P-chan mosfets as the most efficient method of control.
    If you can tolerate a small voltage drop then a simple arrangement such as this will suffice
    http://www.rverscorner.com/info/diode.html
    Dave Johnson has produced a fairly simple circuit using a couple of IC's, some P-chan mosfets and a couple of resistors, if you want the least voltage drop.
    http://www.discovercircuits.com/H-Corner/bat-iso.htm
  5. theamber
    Jun 13, 2008
    318
    You are not going to charge two Deep Cycle 100Ah. marine batteries from one 15W solar panel(this rating usually given at full miday sunlight). Especially if the batteries are connected to the boat and are in a marine eviroment. Also the natural discharge will be more than you can provide. You will need 6.6 days of full power (at 24 hours of full sun a day) to fully charge both batteries that is without the consumption of your regulator and without the natural night discharge, bilge pump,etc.
    As a personal experience with marine batteries I have found that there are certain conditions that can make marine batteries lose a lot of charge depending on the temperature and amount of charge stored when left and other marine air conditions. Also depending if I let both switched in parallel. I think it will be better to let the switch off or on a single battery before leaving. Sometimes I could not start my boat after a few weeks and I had to charge the batteries. I was using two deep cycle lead acid 180Ah. and had two 355ci. 6 cylinders straight Diesels engines. I suggest gell type batteries or AGM.
    This is an amp hour calculator.
    http://www.rpc.com.au/products/services/faq-info/calc/calculator.html
