Dual band antennas?
Discussion in 'General Electronics Chat' started by skybox, May 27, 2010.
  1. skybox
    Thread Starter Active Member
    Mar 2, 2009
    68
    Does anyone have any experience with dual band antennas? The system I am designing for has a transmitter in the range of 2.4[GHz] - 2.51[GHz] and a receiver in the range of 4.8[GHz] - 5.1[GHz].
    Are dual band antennas efficient as single band antennas? Signal rejection the same?
    I am a n00b to antenna selection and theory so looking for some insight. I am trying to find a single band for each of the frequencies and found 2.4 GHz so far for obvious reasons.The 4.8 -5.1 GHz is harder to find, but I've found some dual band antennas in that range.
    Any suggestions would be appreciated.
    The termination of these antennas can either be SMA or RP-SMA
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    In the attached PDF there is a description how to make one on a PCB.
    Bertus
  3. ELECTRONERD
    May 26, 2009
    1,146
    16
    The magazine "Microwave Journal" also has a number of dual-band antenna types, which would be worth checking out. I was able to subscribe to the magazine for free, and I'm sure you can view their articles online. Hopefully they include the full extent of each article.
  4. skybox
    Mar 2, 2009
    68
    Thanks guys. I was just looking to see if there are any "cons" of using a dual band antenna.
