dsPIC33FJ256GP710 ac motor speed controll
Discussion in 'The Projects Forum' started by simplextibi, Feb 10, 2014.
  1. simplextibi
    Feb 10, 2014
    Hi
    I would like to ask if someone has a simple way of controlling 2 pieces of 20W ac 220V 2 wire motors using this dsPIC33?
    I been trying to figure out how to control them using a triac circuit for each but no luck
    Also can you somehow sense the load on them without the 3rd wire?
    I am new to this and would like to do a home project of ventilation
    thank you
  2. Experimentonomen
    Member
    Feb 16, 2011
    331
    46
    You need a single phase variable frequency drive. Though a simple variac usually works well enough on smaller fan motors like this.
  3. shortbus
    Sep 30, 2009
    4,088
    1,669
  4. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    If you want rpm control via Triac, you need a zero cross detection circuit, to get an idea look at Fairchild AN-3006 app note.
    Also Google zero cross detection.
    Max.
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    That's good advice, but you don't always need closed loop control of TRIACS on an AC motor.
    For small power motors with a reasonably constant load (like fans) you can just drive the TRIAC with pulses and get a bit of a hit and miss type effect.
    If you have RPM feedback to the PIC it will work quite well.
