dspic33ev sine pwm
Discussion in 'Embedded Systems and Microcontrollers' started by dandrous, Oct 5, 2016.
  1. dandrous
    Mar 2, 2015
    22
    hi.I need sine modulated pwm output ,iam able to get the pwm,but not able to get sine modulated pwm
    Code (Text):
    1. //////////program.////////
    2. #include <stdio.h>
    3. #include <stdlib.h>
    4. #include "newfile.h"
    5.
    6. #define FCY 20000000 // 20 MIPS
    7. #define FPWM 20000 // 20 kHz
    8. #define _DES_FREQ 60
    9.
    10.
    11.
    12. int i=0;
    13. signed long sinetable[64]={0, 3263, 6493, 9658, 12728, 15671, 18458, 21062,
    14. 23457, 25618, 27525, 29158, 30502, 31542, 32269, 32675, 32757, 32513,
    15. 31945, 31061, 29867, 28377, 26605, 24568, 22287, 19785, 17086, 14217,
    16. 11207, 8085, 4884, 1633, -1633, -4884, -8085, -11207, -14217, -17086,
    17. -19785, -22287, -24568, -26605, -28377, -29867, -31061, -31945, -32513,
    18. -32757, -32675, -32269, -31542, -30502, -29158, -27525, -25618, -23457,
    19. -21062, -18458, -15671, -12728, -9658, -6493, -3263, 0};
    20. void PWM_Init() {
    21.
    22.     PTCON = 0x0000; //Reset configuration register
    23.     PTCON2 = 0x0000;
    24.
    25.     PTCON2bits.PCLKDIV = 0b110; //Set divide for PWM generator to 1:64
    26.
    27.    PTPER = (FCY/FPWM - 1) >> 1;
    28.
    29.
    30.
    31.     MDC = sinetable[i];
    32.     ++i;
    33.     if(i==64)
    34.     {
    35.         i=0;
    36.     }
    37.
    38.     PWMCON1 = 0x0000; //Reset configuration register
    39.     PWMCON2 = 0x0000;
    40.
    41.
    42.
    43.     PWMCON1bits.MDCS = PWMCON2bits.MDCS = PWMCON3bits.MDCS = 1;
    44.
    45.     //MDC provide duty-cycle for PWM generator
    46.
    47.     PWMCON1bits.DTC = PWMCON2bits.DTC = PWMCON3bits.DTC=0b10; //Death-time disable
    48.     PWMCON1bits.CAM = PWMCON2bits.CAM = PWMCON3bits.CAM = 1;; //Center aligned enable
    49.
    50.     TRGCON1 = 0x0000; //Reset configuration register
    51.     TRGCON2 = 0x0000;
    52.
    53.     IOCON1 = 0x0000;
    54.     IOCON1bits.PENH = 1; //PWM module control PWM-H pins
    55.     IOCON1bits.PENL = 1;
    56.     IOCON1bits.PMOD = 0b00; //complimentary output
    57.
    58.     IOCON2 = 0x0000;
    59.     IOCON2bits.PENH = 1;
    60.     IOCON2bits.PENL = 1;
    61.     IOCON2bits.PMOD = 0b00;
    62.
    63.     IOCON3 = 0x0000;
    64.     IOCON3bits.PENH = 1;
    65.     IOCON3bits.PENL = 1;
    66.     IOCON3bits.PMOD = 0b00;
    67.
    68.     FCLCON1 = 0x0000; //Reset configuration register
    69.     FCLCON1bits.FLTMOD = 0b11; //Fault input disable
    70.
    71.     PTCONbits.PTEN = 1; //Enable PWM generator
    72.
    73. }
    74. int main()
    75. {
    76. PWM_Init();
    77.
    78. while(1); /* Infinite Loop */
    79. }
  2. dannyf
    Sep 13, 2015
    2,196
    417
    Start with something simple: can you generate a pulse train with fixed duty cycle?
    Once there, generate a pulse train with variable duty cycle.
    And then a pulse train with a duty cycle pattern that gives you the sine wave.
    You aare trying to run before you can walk.
  3. dandrous
    Mar 2, 2015
    22
    im getting the pulse train,but im not able to get the sine modulated pwm
  4. jayanthd
    Member
    Jul 4, 2015
    275
    29
  5. dannyf
    Sep 13, 2015
    2,196
    417
    Simple then: set duty cycle, wait a fixed period, set duty cycle to the next value, wait a fixed period, set duty cycle to the next value, .... So on and so forth.
    It is so simple that even as caveman can do it.
