dsPIC memory problem
Discussion in 'Embedded Systems and Microcontrollers' started by mik3, Jun 8, 2011.
  1. mik3
    Thread Starter Senior Member
    Feb 4, 2008
    4,846
    63
    Hello guys,
    I am working on a micromouse software and a strange problem appeared.
    There is an array declared as
    int Wall_North [82];
    During the simulation unexpected values appeared in this array, like 73, but only 0s and 1s shall be in the array. Note that the array is initialized to 0. Also, the micromouse does unexpected movements.
    After adding another array Test, which is not used in the algorithm-just shifts the memory locations of the Wall_North array, before the Wall_North it works fine.
    int Test [82];
    Any ideas what can be the problem?
  2. nigelwright7557
    May 10, 2008
    488
    71
    Would need to see your program to give a sensible reply.
  3. ErnieM
    Apr 24, 2011
    7,433
    1,623
    Another pointer out of bounds?
  4. mik3
    Feb 4, 2008
    4,846
    63
    I am not using pointers.
