Say I have a signal which has a component above 50kHz.. and I sample that signal at a rate lower than the Nyquist Frequency ( which is 100kHz ? correct me if i'm wrong).. As a result, aliasing occurs , and the component above the 50Khz appears to be within the 0 - 50kHz range.. Can someone please explain to WHY that happens?
