I am designing a charger that will charge a NiMH battery pack that looks much like two AA packaged together. I've chosen the DS2711 for the charging IC but I've come across a snag that I can't figure out. I will be using a USB cable to charge it so I will have a 5V 500mA output to deal with. There is a sample circuit that Maxim provided on the datasheet but I'm not sure what to do with the feed back signal and the ICHG signal. Could someone help me in the right direction? Thank you!
