Looking for a bit of help...I swear I've had this working before, but right now all I can get is the 185 reading. I have two DS18B20 sensors, one standard and one waterproof. With both I get the 185 reading. Any thoughts?
Included code and pics of breadboard.
Here is my code:
Here is my code:
Code:
<#include <OneWire.h>
int DS18S20_Pin = 4; //DS18S20 Signal pin on digital 2
int relay = 7;
//Temperature chip i/o
OneWire ds(DS18S20_Pin); // on digital pin 2
void setup(void) {
Serial.begin(9600);
void loop(void) {
float temperature = getTemp();
float tempF = (temperature * 9.0)/ 5.0 + 32.0;
Serial.println(tempF);
if (tempF >60) {
digitalWrite(7,HIGH);
} else {
digitalWrite(7,LOW);
delay(100); //just here to slow down the output so it is easier to read
float getTemp(){
//returns the temperature from one DS18S20 in DEG Celsius
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
//no more sensors on chain, reset search
ds.reset_search();
return -1000;
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return -1000;
if ( addr[0] != 0x10 && addr[0] != 0x28) {
Serial.print("Device is not recognized");
return -1000;
ds.reset();
ds.select(addr);
ds.write(0x44, 1); // start conversion, with parasite power on at the end
byte present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for (int i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
ds.reset_search();
byte MSB = data[1];
byte LSB = data[0];
float tempRead = ((MSB << 8) | LSB); //using two's compliment
float TemperatureSum = tempRead / 16;
return TemperatureSum;
