1. Dumken
    Oct 7, 2014
    23
    Code (Text):
    1.
    2. // LCD module connections
    3. Pls help me understand the coloured potion in this code
    4.
    5.
    6. sbit LCD_RS at RB2_bit;
    7. sbit LCD_EN at RB3_bit;
    8. sbit LCD_D4 at RB4_bit;
    9. sbit LCD_D5 at RB5_bit;
    10. sbit LCD_D6 at RB6_bit;
    11. sbit LCD_D7 at RB7_bit;
    12.
    13. sbit LCD_RS_Direction at TRISB2_bit;
    14. sbit LCD_EN_Direction at TRISB3_bit;
    15. sbit LCD_D4_Direction at TRISB4_bit;
    16. sbit LCD_D5_Direction at TRISB5_bit;
    17. sbit LCD_D6_Direction at TRISB6_bit;
    18. sbit LCD_D7_Direction at TRISB7_bit;
    19. // End LCD module connections
    20.
    21.
    22.
    23. unsigned short read_ds1307(unsigned short address)
    24. {
    25.   unsigned short r_data;
    26.   I2C1_Start();
    27.   I2C1_Wr(0xD0); //address 0x68 followed by direction bit (0 for write, 1 for read) 0x68 followed by 0 --> 0xD0
    28.   I2C1_Wr(address);
    29.   I2C1_Repeated_Start();
    30.   I2C1_Wr(0xD1); //0x68 followed by 1 --> 0xD1
    31.   r_data=I2C1_Rd(0);
    32.   I2C1_Stop();
    33.   return(r_data);
    34. }
    35.
    36.
    37. void write_ds1307(unsigned short address,unsigned short w_data)
    38. {
    39.   I2C1_Start(); // issue I2C start signal
    40.   //address 0x68 followed by direction bit (0 for write, 1 for read) 0x68 followed by 0 --> 0xD0
    41.   I2C1_Wr(0xD0); // send byte via I2C (device address + W)
    42.   I2C1_Wr(address); // send byte (address of DS1307 location)
    43.   I2C1_Wr(w_data); // send data (data to be written)
    44.   I2C1_Stop(); // issue I2C stop signal
    45. }
    46.
    47.
    48. unsigned char BCD2UpperCh(unsigned char bcd)
    49. {
    50.   return ((bcd >> 4) + '0');
    51. }
    52.
    53.
    54. unsigned char BCD2LowerCh(unsigned char bcd)
    55. {
    56.   return ((bcd & 0x0F) + '0');
    57. }
    58.
    59.
    60. int Binary2BCD(int a)
    61. {
    62.    int t1, t2;
    63.    t1 = a%10;
    64.    t1 = t1 & 0x0F;
    65.    a = a/10;
    66.    t2 = a%10;
    67.    t2 = 0x0F & t2;
    68.    t2 = t2 << 4;
    69.    t2 = 0xF0 & t2;
    70.    t1 = t1 | t2;
    71.    return t1;
    72. }
    73.
    74.
    75. int BCD2Binary(int a)
    76. {
    77.    int r,t;
    78.    t = a & 0x0F;
    79.    r = t;
    80.    a = 0xF0 & a;
    81.    t = a >> 4;
    82.    t = 0x0F & t;
    83.    r = t*10 + r;
    84.    return r;
    85. }
    86.
    87. int second;
    88. int minute;
    89. int hour;
    90. int hr;
    91. int day;
    92. int dday;
    93. int month;
    94. int year;
    95. int ap;
    96.
    97. unsigned short set_count = 0;
    98. short set;
    99.
    100. char time[] = "00:00:00 PM";
    101. char date[] = "00-00-00";
    102.
    103. void main()
    104. {
    105.    I2C1_Init(100000); //DS1307 I2C is running at 100KHz
    106.
    107.    CMCON = 0x07;   // To turn off comparators
    108.    ADCON1 = 0x06;  // To turn off analog to digital converters
    109.
    110.    TRISA = 0x07;
    111.    PORTA = 0x00;
    112.
    113.    Lcd_Init();                        // Initialize LCD
    114.    Lcd_Cmd(_LCD_CLEAR);               // Clear display
    115.    Lcd_Cmd(_LCD_CURSOR_OFF);          // Cursor off
    116.    Lcd_out(1,1,"Time:");
    117.    Lcd_out(2,1,"Date:");
    118.
    119.    do
    120.    {
    121.      set = 0;
    122.      if(PORTA.F0 == 0)
    123.      {
    124.          Delay_ms(100);
    125.          if(PORTA.F0 == 0)
    126.          {
    127.              set_count++;
    128.              if(set_count >= 7)
    129.              {
    130.                 set_count = 0;
    131.              }
    132.          }
    133.      }
    134.      if(set_count)
    135.      {
    136.         if(PORTA.F1 == 0)
    137.         {
    138.           Delay_ms(100);
    139.           if(PORTA.F1 == 0)
    140.               set = 1;
    141.         }
    142.
    143.         if(PORTA.F2 == 0)
    144.         {
    145.           Delay_ms(100);
    146.           if(PORTA.F2 == 0)
    147.               set = -1;
    148.         }
    149.         if(set_count && set)
    150.         {
    151.           switch(set_count)
    152.           {
    153.            [COLOR=#80ff00] case 1:
    154.                     hour = BCD2Binary(hour);
    155.                     hour = hour + set;
    156.                     hour = Binary2BCD(hour);
    157.                     if((hour & 0x1F) >= 0x13)
    158.                     {
    159.                       hour = hour & 0b11100001;
    160.                       hour = hour ^ 0x20;
    161.                     }
    162.                     else if((hour & 0x1F) <= 0x00)
    163.                     {
    164.                       hour = hour | 0b00010010;
    165.                       hour = hour ^ 0x20;
    166.                     }
    167.                     write_ds1307(2, hour); //write hour
    168.                     break;[/COLOR]
    169.             case 2:
    170.                      minute = BCD2Binary(minute);
    171.                      minute = minute + set;
    172.                      if(minute >= 60)
    173.                         minute = 0;
    174.                      if(minute < 0)
    175.                         minute = 59;
    176.                      minute = Binary2BCD(minute);
    177.                      write_ds1307(1, minute); //write min
    178.                      break;
    179.             case 3:
    180.                     if(abs(set))
    181.                       write_ds1307(0,0x00); //Reset second to 0 sec. and start Oscillator
    182.                     break;
    183.             case 4:
    184.                      day = BCD2Binary(day);
    185.                      day = day + set;
    186.                      day = Binary2BCD(day);
    187.                      if(day >= 0x32)
    188.                         day = 1;
    189.                      if(day <= 0)
    190.                         day = 0x31;
    191.                      write_ds1307(4, day); // write date 17
    192.                      break;
    193.             case 5:
    194.                     month = BCD2Binary(month);
    195.                     month = month + set;
    196.                     month = Binary2BCD(month);
    197.                     if(month > 0x12)
    198.                       month = 1;
    199.                     if(month <= 0)
    200.                       month = 0x12;
    201.                     write_ds1307(5,month); // write month 6 June
    202.                     break;
    203.             case 6:
    204.                     year = BCD2Binary(year);
    205.                     year = year + set;
    206.                     year = Binary2BCD(year);
    207.                     if(year <= -1)
    208.                        year = 0x99;
    209.                     if(year >= 0x50)
    210.                        year = 0;
    211.                     write_ds1307(6, year); // write year
    212.                     break;
    213.           }
    214.         }
    215.      }
    216.
    217.       second = read_ds1307(0);
    218.       minute = read_ds1307(1);
    219.       hour = read_ds1307(2);
    220.        hr = hour & 0b00011111;
    221.        ap = hour & 0b00100000;
    222.       dday = read_ds1307(3);
    223.       day = read_ds1307(4);
    224.       month = read_ds1307(5);
    225.       year = read_ds1307(6);
    226.
    227.
    228.       time[0] = BCD2UpperCh(hr);
    229.       time[1] = BCD2LowerCh(hr);
    230.       time[3] = BCD2UpperCh(minute);
    231.       time[4] = BCD2LowerCh(minute);
    232.       time[6] = BCD2UpperCh(second);
    233.       time[7] = BCD2LowerCh(second);
    234.
    235.       date[0] = BCD2UpperCh(day);
    236.       date[1] = BCD2LowerCh(day);
    237.       date[3] = BCD2UpperCh(month);
    238.       date[4] = BCD2LowerCh(month);
    239.       date[6] = BCD2UpperCh(year);
    240.       date[7] = BCD2LowerCh(year);
    241.
    242.       if(ap)
    243.       {
    244.          time[9] = 'P';
    245.          time[10] = 'M';
    246.       }
    247.       else
    248.       {
    249.          time[9] = 'A';
    250.          time[10] = 'M';
    251.       }
    252.
    253.
    254.       Lcd_out(1, 6, time);
    255.       Lcd_out(2, 6, date);
    256.       Delay_ms(100);
    257.
    258.
    259.    }while(1);
    260. }
    261.
    Moderators note : Please use code tags for pieces of code
  2. ErnieM
    Apr 24, 2011
    7,436
    1,626
    No colors. Too bad, so sad.
    The only thing that jumped out at me is time[10] is initialized as 'M' is never anything different than 'M' and thus never needs to be changed ever. ;)
    Code tags are great but I think they kill colors. Either name the routine or make a source listing with line numbers and note the numbers you need help with.
