Hello, everyone.
I am trying to display date & time from RTC Ds1307 on LCD using Pic 18f4520 MCU. I have also connected a push button on PORTA and by pressing it Time & date should display.
Sometime i get garbage value but most time nothing at all.
I have attached my code guys. PLEASE go through it & Kindly HELP me.
Rich (BB code):
// Lcd module connections
sbit LCD_RS at LATB0_bit;
sbit LCD_EN at LATB1_bit;
sbit LCD_D4 at LATB2_bit;
sbit LCD_D5 at LATB3_bit;
sbit LCD_D6 at LATB4_bit;
sbit LCD_D7 at LATB5_bit;
sbit LCD_RS_Direction at TRISB0_bit;
sbit LCD_EN_Direction at TRISB1_bit;
sbit LCD_D4_Direction at TRISB2_bit;
sbit LCD_D5_Direction at TRISB3_bit;
sbit LCD_D6_Direction at TRISB4_bit;
sbit LCD_D7_Direction at TRISB5_bit;
// Lcd constants
char txt1[] = "SPG INFOTECH";
char txt2[] = "DIGITAL CLOCK";
char txt3[] = "DATE:";
char txt4[] = "TIME:";
// Module variables
unsigned char hours, minutes, seconds, day, week, month, year; // Global date/time variables
char oldstate = 0;
// RTC Definitions
#define RTC_ADDR 0xD0
* DS1307 Functions
* Read data from RTC DS1307
* input : addres of RTC register
* output: value of of RTC register
unsigned char RTC_Read(unsigned char addr){
unsigned char value;
I2C1_Start(); // Issue start signal
I2C1_Wr(RTC_ADDR); // Address DS1307, see DS1307 datasheet
I2C1_Wr(addr); // Start from address 2
I2C1_Start(); // Issue repeated start signal
I2C1_Wr(RTC_ADDR); // Address DS1307 for reading R/W=1
value = I2C1_Rd(0); // Read seconds byte
I2C1_Stop(); // Issue stop signal
return value;
* Write data from DS1307
* input : addres of RTC register, value of of RTC register
void RTC_Write(unsigned char addr, unsigned char value){
I2C1_Wr(value); // Write value to RTC register
* Read time from RTC DS1307
* input : pointer to variables where RTC data will be stored
* output: variables with RTC data
void Read_Time(unsigned char *p_hours, unsigned char *p_minutes, unsigned char *p_seconds,
unsigned char *p_day, unsigned char *p_week, unsigned char *p_month, unsigned char *p_year){
I2C1_Wr(0); // Start from address 0
I2C1_Repeated_Start(); // Issue repeated start signal
I2C1_Wr(RTC_ADDR + 1); // Address DS1307 for reading R/W=1
*p_seconds = I2C1_Rd(1); // Read seconds byte
*p_minutes = I2C1_Rd(1); // Read minutes byte
*p_hours = I2C1_Rd(1); // Read hours byte
*p_week =I2C1_Rd(1);
*p_day =I2C1_Rd(1);
*p_month =I2C1_Rd(1);
*p_year =I2C1_Rd(0);
* Write time to RTC DS1307
* input : variables with RTC data
void Write_Time(unsigned char c_hours, unsigned char c_minutes, unsigned char c_seconds,
unsigned char c_day, unsigned char c_week, unsigned char c_month, unsigned char c_year){
I2C1_Start(); // issue start signal
I2C1_Wr(RTC_ADDR); // address DS1307
I2C1_Wr(0); // start from word at address (REG0)
I2C1_Wr(0x80); // write $80 to REG0. (pause counter + 0 sec)
I2C1_Wr(c_minutes); // write 0 to minutes word to (REG1)
I2C1_Wr(c_hours); // write 17 to hours word (24-hours mode)(REG2)
I2C1_Wr(c_week); // write 2 - Monday (REG3)
I2C1_Wr(c_day); // write 4 to date word (REG4)
I2C1_Wr(c_month); // write 5 (May) to month word (REG5)
I2C1_Wr(c_year); // write 01 to year word (REG6)
I2C1_Stop(); // issue stop signal
I2C1_Wr(0); // start from word at address 0
I2C1_Wr(0 | c_seconds); // write 0 to REG0 (enable counting + 0 sec)
* Show on the LCD display
void Show_Time(){
char *txt;
seconds = ((seconds & 0x70) >> 4)*10 + (seconds & 0x0F);
minutes = ((minutes & 0xF0) >> 4)*10 + (minutes & 0x0F);
hours = ((hours & 0x30) >> 4)*10 + (hours & 0x0F);
week = (week & 0x07);
day = ((day & 0xF0) >> 4)*10 + (day & 0x0F);
month = ((month & 0x10) >> 4)*10 + (month & 0x0F);
year = ((year & 0xF0)>>4)*10+(year & 0x0F);
switch(week)
case 1: txt="Sun"; break;
case 2: txt="Mon"; break;
case 3: txt="Tue"; break;
case 4: txt="Wed"; break;
case 5: txt="Thu"; break;
case 6: txt="Fri"; break;
case 7: txt="Sat"; break;
/*LCD_Out(1,1, txt);*/
Lcd_Out(1, 6, (day / 10) + 48); // Print tens digit of day variable
Lcd_Out(1, 7, (day % 10) + 48); // Print oness digit of day variable
Lcd_Out(1, 9, (month / 10) + 48);
Lcd_Out(1,10, (month % 10) + 48);
Lcd_Out(1,14, (year / 10) + 48);
Lcd_Out(1,15, (year % 10) + 48);
Lcd_Out(2, 6, (hours / 10) + 48);
Lcd_Out(2, 7, (hours % 10) + 48);
Lcd_Out(2, 9, (minutes / 10) + 48);
Lcd_Out(2,10, (minutes % 10) + 48);
Lcd_Out(2,12, (seconds / 10) + 48);
Lcd_Out(2,13, (seconds % 10) + 48);
* MAIN PROGRAM
void main(){
ADRESL = 0;
ADRESH = 0;
CMCON =7;
PORTA = 0;
TRISA =1;
LATA=1;
ADCON0 =0;
ADCON1 =0;
ADCON2 = 0;
TRISA = 0b00000111;
PORTD = 0;
I2C1_Init(100000); // Initialize I2C bus for communication with RTC
Lcd_Init(); // Initialize Lcd
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
Lcd_Out(1,1,txt1); // Write text in first row
Lcd_Out(2,4,txt2); // Write text in second row
Delay_ms(2000); // delay 2 sec
Lcd_Cmd(_LCD_CLEAR); // Prepare and output static text on LCD
LCD_Chr(1,8,'.');
LCD_Chr(1,11,'.');
LCD_Out(2,1,txt3);
LCD_Out(1,1,txt4);
LCD_Chr(2,8,':');
LCD_Chr(2,11,':');
LCD_Out(1,12,"20");
// Start the test examples
while(1){ // Endless loop
if (Button(&PORTA, 1, 1, 1)) { // Detect logical one
oldstate = 1; // Update flag
if (oldstate && Button(&PORTA, 1, 1, 0)) { // Detect one-to-zero transition
// Write TIME 11 : 15 : 00 : 24. tuesday april 2012
Write_Time(0x11, 0x15, 0x00, 0x24, 0x03, 0x04, 0x12);
oldstate = 0; // Update flag
Read_Time(&hours, &minutes, &seconds, &day, &week, &month, &year);
Show_Time();
Delay_mS(10);
* End of File
