dropping resistor value
Discussion in 'General Electronics Chat' started by Gompers, Feb 21, 2007.
  1. Gompers
    Feb 21, 2007
    18
    Newbie here Name's Ed. Trying to find the right dropping resistor value
    to convert a plug in DC power supply of 5.0 volts @1.0amps to 3.0 (DC)volts to power a miniature Am/Fm radio that eats up batteries.
    Thanx in advance Ed.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It's hard to come up with a good value for a dropping resistor, as the value is only good for one load value. Just grab 4 diodes, like 1N914's, and tie then all in series. They will drop about 2.8 volts and make a better source for your radio.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    He only needs to drop 2 volts. Three diodes should do it.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Wow, how did I come up with 3 volts? Good catch.
  5. Gompers
    Feb 21, 2007
    18
    Thanx, Ron and Beenthere I have a whole boxful of diodes, but how do I identify a 1n914? ED
  6. wireaddict
    Nov 1, 2006
    133
    The no. is usually printed on the side of the case but you'll need a magnifying glass unless your eyes are a lot better than mine.
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Any silicon diode should do. The 1N914 is a signal diode, but a rectifier type, like a 1N4001 will also work.
  8. Gompers
    Feb 21, 2007
    18
    Been and Ron thanx again used four silicon diodes and VOILA! works fine
    Next, I want to try to convert a similar plug-in to a lower voltage for use as battery eliminator for my Coolpix camera. Never thoughtof using diodes as resistors? Might make a decade box for quick voltage drop search??Cheers, Ed.
  9. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    They are not really dropping resistors. They require a certain energy to be expended to push electrons across the P-N barrier. That's about .7 volts for silicon, and about .2 volts for germanium.
    They come in handy for wall wart voltage droppers.
  10. tek_fool
    Feb 24, 2007
    12
  11. tek_fool
    Feb 24, 2007
    12
