Dropper resistor
Discussion in 'Homework Help' started by hackers99, Nov 18, 2009.
Thread Status:
Not open for further replies.
  1. hackers99
    Nov 18, 2009
    36
    sorry...........
  2. hackers99
    Nov 18, 2009
    36
    hey guyz plz help...
  3. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    You're going to have to learn patience. Are you writing the exam while texting?
  4. hackers99
    Nov 18, 2009
    36
    sorry ya...
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I am by no means sure that this is the correct approach. No one resistor value will work for all combinations of load. Where did you get the idea that it was?
    If you want to split the power dissipation among several chips then I recommend an emitter follower preregulator made from an NPN, a resistor and a zener diode. You can easily extend this to provide a measure of protection from polarity reversal and loss of ground. Checkout the following which is easy to google with "Zener Diode Preregultor"
    http://sound.westhost.com/project102.htm
    If I was doing this I'd pick about at least an 18V Zener to make sure the 7815 had plenty of headroom.
    The 7805 will draw 0.045*(15-5) = 450 milliwatts
    The 7815 will draw (0.045+0.020)*(18-15) = 195 milliwatts
    The Emitter Follower will draw 0.065*(30-18) = 780 milliwatts
    A higher value zener will distribute the dissipation between the Emitter Follower and the 7815 more evenly if that is worthwhile to you. You might try a 22V zener, I don't think they come in 22.5V models.
    Theta(JA) for a TO-220 package is 65 degrees C per watt, so limiting the dissipation to a half watt seems like a good idea. So your three devices at 500 milliwatts would be at 20 + 32.5 = 52.5 degrees C or 126.5 degrees F; warm but not finger burning hot.
  6. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Wonder when the exam ends? Isn't using the internet on your cell a form of cheating?
  7. hackers99
    Nov 18, 2009
    36
    papa thnks man for ur ideas...
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Ya mean I wasted my time giving him an answer he can't use? Can I get the A instead? Maybe an attaboy? Heavy Sigh....
  9. hackers99
    Nov 18, 2009
    36
    is the dropper part of circuit consume more input power...........
  10. hackers99
    Nov 18, 2009
    36
    can u tell me what is the meaning of "in addition to the current drawn by 7805"...
  11. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Which part consumes what power is up to you. I started with a minimum zener value of 18V and calculated the PD for each part. Since they were unbalanced, I suggested a zener value of 22V or 23V since the ideal value of 22.5 V probably does not exist.
    You yourself said that the 7805 draws 45 mA. This current must also flow through the 7815, and there is an additional 20 mA required by the 15V parts. So we have 65 mA flowing through the 7815 and this same current must flow through the Emitter Follower.
    The problem with dropping resistors is that they only work for a single set of load conditions. You never answered the question. Where did you get the idea that dropping resistors are an appropriate way to distribute power?
  12. hackers99
    Nov 18, 2009
    36
    sorry delete this thread...
  13. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    No thanks - this is just strange enough as is. Your instructor probably won't look for your posts anyway.
  14. Papabravo
    Feb 24, 2006
    10,340
    1,850
    What? Why would you want this thread deleted? I expended some effort on those responses. They contain some useful information. Fortuneately, thread deletion is not one of those things that you get to decide.
Thread Status:
