Hello everyone,
I am stuck in my experience. I would like to be able to charge my phone on a 12V battery (7 Ah). To do such a thing, I use a DC/ DC Car Power Converter to adapt voltage from 12V to 5V. Then, I placed a diode to isolate the circuit. Because I will add an other 5V input (from a cell phone charger), and i want to isolate the 12V battery from this second input. (The board I want to build will be able to charge my phone when it is connected to the cell phone charger or the 12V battery.) And last but not least, I put a red LED and its resistor (165 ohms) in parallel in order to know when the phone receives power from the battery.
The problem is that the voltage decreases to 4.47V which is insufficient to charge the phone (nominal voltage is 5V). I know that the LED normally induces a drop of voltage when placed in series, but that's why i placed it in parallel.
So, here are my questions:
Does a LED in parallel induces adrop of voltage? Or the voltage drop is due to another thing?
If the LED really induces a drop of voltage, how could I obtain a 4.92V to charge my phone, and keep my LED in the board?
