Drop 48VDC to 12VDC ?
Discussion in 'General Electronics Chat' started by SteveDouglas, Aug 16, 2012.
  1. SteveDouglas
    Thread Starter Active Member
    Apr 30, 2009
    42
    I have a 48 volt, 7 amp PS and need to drop down to 12 volts to run two 12 volt 60mm cooling fans each drawing 20ma. I know a LM7812 wont work and think maybe a simple 2 resistor voltage divider will do it.
    Can someone advise what resistor values and wattages are required ?
    The 48v PS is in my project case with very little room left and this PS is required for the main supply of my project, I just want to add the cooling fans to keep the case cool.
    Thanks,
    Steve
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    Put the two 12V fans in series. Now your load is 24V @ 20mA.
    The effective resistance is 24V/0.02A = 1200Ω
    Now you need to burn off 48V - 24V @ 0.02A, i.e. the same amount as the load.
    Hence you need a 1200Ω resistor in series.
    Calculate the wattage = 24V x 0.02A = 0.48W
    Use a 1200Ω resistor, 1W or higher.
    jwilk13 likes this.
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
    DC motors may not like a resistor in series with their power source. I like stacking the fans in series, but you could feed them from a really cheap voltage source with a 24V Zener and a 100V NPN transistor in a TO-220 case, no heatsink needed if you use TO-220 and load is 20 mA.
    I think you could also use an LM317HV to create 24V from 48V.
  4. Bernard
    Aug 7, 2008
    4,231
    414
    Or how about a 5W, 20V zener [ NTE 5135A ] in series with 240 Ω, providing about 60 mA starting current? ; or just a 24 V zener, 5 W [NTE5137A ], about 2.5W at start up.
  5. Dodgydave
    Jun 22, 2012
    5,134
    767
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    I may try to draw a crude buck boost converter for this, if you are interested.
  7. bountyhunter
    Sep 7, 2009
    2,498
    507
    I may be slow in my old age but enlighten me:
    Why would anybody go through all that trouble when you can just use an LM317HV which will not need a heatsink? It will also provide short circuit and thermal protection if the fan gets blocked and draws excess current.
    Sometimes life can be simple.
  8. bountyhunter
    Sep 7, 2009
    2,498
    507
  9. nigelwright7557
    May 10, 2008
    488
    71
    I would put the two fans in series with a high power 1K8 resistor.
    I did the same for a disco amplifier I had and it worked a treat.
    Although I think the fans were 200mA not 20mA !
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    Assuming a LM317T could regulate 48V to 12V (which it can't, out of spec)...
    36V X 0.02 = 0.64W
    Hot enough to burn fingertips.
  11. bountyhunter
    Sep 7, 2009
    2,498
    507
    You need to read my post:
    I said to use an LM317HV, not an LM317 standard. The HV version handles input working voltage up to 60V.
    And FYI: the thermal resistance of the TO-220 pkg with no heatsink is 65C/W. At 0.64W, that raises the junction temp to maybe 65C. Absolutely no problem. Solder it down to a small copper patch on the PCB and it drops to about 30C/W thermal resistance.
    Like I said: Use the LM317HV in the TO-220 pkg.
    http://pdf1.alldatasheet.com/datasheet-pdf/view/8608/NSC/LM317HV.html
