Hello all,
I'm creating an electronic organ that has about 50 or so draw knobs. (A draw knob on an organ is what you pull out to add sounds and push in to take away sounds). Each stop has to have a solenoid to pull it in and out, so I'll need about 100 or so solenoids. But I have no idea how to power them. The solenoids will be about 9 or 12 Volts, and they need to be driven by a 1-3 volt signal from an I/O board. I will have to be able to power at least 40-50 of them at once. They will only have to push/pull between 5/8 and 1 inch horizontally, with probably less than 10 ounces. I'm trying to do this for as little money as possible. I read on other articles that old VCRs have solenoids so I'll look into that. But I was going to wound each solenoid myself, do the wiring, and just buy an I/O board.
So ultimately my question is how do I do this?
Ray
Ray
