Driving power FET's
Discussion in 'General Electronics Chat' started by sage.radachowsky, May 11, 2010.
  1. sage.radachowsky
    May 11, 2010
    241
    38
    I am very interested in the topic of shoot-through, and how to drive power FETs from microcontrollers.
    Let me make some comments with my 2 cents, and then I hope to learn from surfline and others. That is why I am bumping this thread, to continue to learn about this.
    In your first paragraph you say you want a NMOS and PMOS combo with near identical Vg(th). These are definitely available, if you search Digikey for MOSFET arrays and select "N and P". But what I really think you want is to get a pair of FETs where each Vg(th) is more than half the swing of your signal. In this case, 5V is your signal swing so you want something with threshold above 2.5V (or below -2.5V for the PMOS). If you get something with a 1V threshold, then you'll have a whole 3V from 1V to 4V where both FETs are somewhat on. Does that sound right to you?
    My recommendation for making a power FET drive using the 5V microcontroller is to separately drive the gate of the N and the P driver MOSFETs. This way, you can turn off one FET, then in the next instruction cycle, you can turn on the other one. There will be no overlap, and a very short delay where the output is not driven. If the output is driving the gate of a power FET, then it should be fine to have it high impedance for a couple microseconds -- it will just stay where it is since it's a capacitor.
    My last thought on shoot-through is that if the power & speed of the drive is not important, then it is okay to put a resistor between the drains of a CMOS pair. This way, the shoot-through will be limited by the resistor. Maybe 100 Ohm or 1000 Ohm depending on the application. For slower signals this is often okay.
    Look forward to comments.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. sage.radachowsky
    May 11, 2010
    241
    38
    Dear Moderator,
    Thank you for moving my post to another thread.
    After I wrote the post, I had another thought. What about the circuit in the image. It is a CMOS pair, but the gate transitions should be delayed for turning on, and accelerated for turning off, so if the resistor is big enough, then it should eliminate shoot-through.
    Has anyone else used this technique?
