Driving multiple Rgb leds-Please help
Discussion in 'The Projects Forum' started by makavelly001, Mar 13, 2011.
  1. makavelly001
    Mar 12, 2011
    5
    Hi all, My name is Lesly and I Am obsessed with this idea that I have. Unfortunately, when it comes to electronics im blind, deaf and mute. In all my obsession is to effectively and efficiently drive 35-40 SMD RGB leds. I have found this great controller that appears suitable for driving the leds.
    1. I want to connect the leds to my 12v car battery
    A: Will a 12 v car battery supply sufficient voltage and current?
    B: If not, how do I boost the power supply and maintain constant voltage and current?
    2: Parallel or series?
    A: Should the leds be in series or parallel.
    B: How long should each strand be.
    3: Components I am Using - Controller and Leds
    RGB Controller- MultiLine RGB Fader V2.0
    - Speeds: 9
    - Channels: 3
    - Status LEDs: 12
    - 16.000.000 colors
    - Reverse polarity protection
    - PWM: 150Hz (no flickering!)
    - Input: 7-30V DC
    - Output: Depending on the input
    - Uses common anode (plus)
    - Dimensions (LxWxH): 110x111x25mm
    - Max. capacitance per channel: 10A
    - Max. LED forward voltage: 35V DC
    - Max. total capacitance of illuminants: 20A over soldering pads or 16A over clamps
    * Can I use the MCP1630 Boost Mode LED Driver Demo Board to boos the controller.
    http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en530202&part=MCP1630DM-LED2
    PCB with 5 LEDs provide for evaluation
    Compact size with high output power
    High efficiency over entire operating input voltage range
    Selectable 350 mA or 700 mA output current
    Up to 30W output power
    Optional software dimming control
    500 kHz switching frequency can be changed in firmware
    Additional application functions can be provided in firmware
    RGB LEDS
    Forward voltage min typical max for. current
    RED LED 2.0 2.3 2.8 120 ma
    GREEN LED 3.0 3.5 4.0 150 ma
    BLUE LED 3.0 3.5 4.0 150ma
    http://www.kingbrightusa.com/product.asp?catalog_name=LED&product_id=AAAF5051-03
    Please help in any way you can Im willing to PAY
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Why do you want to use your car battery?
  3. makavelly001
    Mar 12, 2011
    5
    Thanks for reading,i want to use the car battery bcause the application is for auto use.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
