Hi all,
I'm sure this has probably been covered before, I've searched around a bit but am still unsure as the best way to do it!
I've found a handy looking mosfet h-bridge on a chip, nice and cheap etc. I'd like to drive a lc circuit with it for rfid purposes (mainly experimenting a bit!).
Quite a few of the circuits I've found with a search use two bjt (I think) transistors to drive the high and low side of the bridge.....
The H-bridge I have is laid out like this,
The data sheet says this!
Do I need to use four more transistors to drive the mosfets on the H-Bridge? I think its the value VGS I'm interested in? Does this mean my chip has a low switch on voltage or does it mean I need 1v min to 3v max above the source voltage? The more I search on this one the more confused I get!
I've also attached the whole data sheet as a PDF.
Thanks Geoff
Thanks Geoff
