I need to drive a STP75NF75 N channel MOSFET from the PWM signal produced from a PIC microcontroller. The frequency will be 10MHZ. What kind of driver circuit will I need between the PIC and the MOSFET? The input capcitance is listed as 3700pf. The PIC runs off 5 volts. The MOSFET will switch 12 volts. Does the gate volate need to be at 12 volts instead of 5?
Thanks for any ideas. I appreciate it.
Thanks,
Brian
Thanks,
Brian
