Driving incandescent lamp
Discussion in 'Embedded Systems and Microcontrollers' started by El_da, Aug 17, 2009.
  1. El_da
    Aug 17, 2009
    10
    I have PIC12F629 and want with I/O port drive IRFP450. I attached wiring diagram.
    With IRFP450 I want to drive 230V~ regular bulb 100W. Can I drive IRFP450 directly?
    Is my wiring diagram OK?
    thanks
  2. El_da
    Aug 17, 2009
    10
    Sorry,
    I forgot to upload wiring diagram :)
  3. Amberwolf
    Member
    May 2, 2008
    28
    If that's 230V *AC*, then I think you need to first read the AAC ebooks before you start designing this circuit. ;)
    Even if it's DC, you'll be better off using a driver (discrete or chip) for the MOSFET, if for no other reason than so a failure doesn't pop your PIC.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Welcome, El da.
    I have moved your posts to their own thread. We refer to posting in an existing thread hijacking, and ask that you not do it. Especially when the old thread is very old - http://forum.allaboutcircuits.com/showthread.php?t=8270&page=3
    You can't use a FET to control AC. Look at the data sheet and see the inherent diode in the FET structure. It is better to use a TRIAC to control AC.
  5. El_da
    Aug 17, 2009
    10
    Thank you beenthere,
    live and learn is my moto, thank you for your advices,
    regards
