Driving an SSR through a Serial Port
Discussion in 'The Projects Forum' started by fester225, Nov 12, 2008.
  1. fester225
    Nov 11, 2008
    6
    I was going to drive my Solid State Relay from a printer port, but I'm limited to working with an XP system, and XP doesn't like to give direct access to the printer ports.
    What about driving an SSR through a Serial Port in an XP system? (I'm controlling a bell.) I assume there's something on a serial port which can be directly controlled from software. Is there any handshaking to do?
  2. KMoffett
    Dec 19, 2007
    2,584
    234
  3. fester225
    Nov 11, 2008
    6
    I meant a 9-pin Serial Port.
  4. KMoffett
    Dec 19, 2007
    2,584
    234
    The USB module was just an alternative for the serial port, if you could get it to work. :)
    Ken
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    XP has nothing to do with it. Use any language that gives low-level hardware access.
