Hi everyone. I have a project which illustrates the driving of a linear induction motor (LIM). We are obligated to supply four square current waves with 90 degree phase difference, at least 300mArms amplitude and adjustable frequency from 20Hz to 200; to four 50mH inductor (with inner resistivity of 20 ohm). As a result, we will get a moving electromagnetic field between that four inductor. We can use only lm741 opamp, whole transistor types and other basic circuit elements with only a DC power supply. At this stage, i have obtained 4-phase voltage waveforms with 12 volt amplitude and adjustable frequency, but i have problems with the next stage. I have a well current wave on inductor with the following circuit (http://img196.imageshack.us/img196/911/circd.jpg) On 20 ohm, there is a good square wave with 500mV Vpp, which corresponds to a poor 25mA max value. This is why i use the base terminal of bjt. Hovewer, with any other variations of terminals, the current waveform collapsed. When i have removed the opamp from that configuration, i also can't obtain a square voltage on the resistor, it behaves as RLC circuits. I also try mosfet with similar circuits. Is there any idea for that problem?
