Driving a transistor from HT12D
André Ferrato
Joined Apr 5, 2015
215
Hello, i intend to drive a transistor from HT12D outputs. I took a quick look through the datasheet and saw the Data Output Source Current and it's negative, this means that i cannot drive an NPN right ? Because i need to feed current to the NPN and as the Output is only sinking... Am i correct ?
MikeML
5,444
Looks like it will source ~1mA. Try 4.7K between the data pin and the base of an NPN whose emitter is tied to Vss (0V).
André Ferrato
Joined Apr 5, 2015
215
Oh i see.. but, when it says SOURCE, it means current getting out of the device right ? So by negative sign it means it's on the opposite direction, so it's SINKING, that's the way i see it or i am missing something ? Some semantics..
dl324
Joined Mar 30, 2015
16,943
Source is represented as a negative current, source is represented as a positive current. If you look at the output voltage, it will be apparent which way (conventional) current is going.
AnalogKid
Joined Aug 1, 2013
11,056
Semantics - exactly. Your interpretation would be correct except for one thing - the datasheet is not well written in an unambiguous way. DL is correct, the datasheet is confusing, and that's just something you have to live with when 1000 companies are writing datasheets with no absolute rules to follow.
ak
