Hello, I have programmed a BX24 chip to output logic highs and lows and PWM signals that are currently controlling 12 volt circuits, pumps, valves and relays via MOSFETS.
I wish to recterfy 240 VAC to DC and use a power MOSFET (500V 53 Amp) to control a 110Volt DC motor.
With 240 VDC across the MOSFET is it possible to drive the gate with a 5V logic high from a BX24 chip? I have tried it with 12 Volts and that is ok but not sure what to expect with the higher voltage.
Thanks for taking the time to consider my question.
Graeme
Graeme
