driving a MCU with CLK OUT
Discussion in 'General Electronics Chat' started by bug13, Jul 10, 2013.
  1. bug13
    Feb 13, 2012
    1,214
    38
    Hi guys
    Can I drive the MCP2200 with the CLK OUT pin of a MCU? Say I connect CLK OUT pin to OSC1 of MCP2200, and ground OSC2?
    Thanks guys
  2. Ron H
    Apr 14, 2005
    7,050
    657
    I have no experience with this part, but the block diagram shows that OSC2 is an output, so just leave it floating. You should be able to drive OSC1 with the CLK OUT from your MCU, assuming both parts have the same Vcc.
    I can't guarantee that the frequency is correct, of course.
    bug13 likes this.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    It will need a good 12MHz clock source, in order to work. What this source is as long as it fits the spec. Does not matter much
    bug13 and Ron H like this.
